fits link
https://www.mediafire.com/file/n2d76o7qzzliyqn/Cygnus_135mm_Widefield_Asi533.fits/file
Tiff link for reduced file size
https://www.mediafire.com/file/zxzw75kp2ogyuoq/Cygnus135mmAsi533.tif/file
Alpha Zhang:
Hi tantalusthief,
Poor focus and tilt. You may want to be careful there.
Julian Shroff:
Hi there,
I had a quick stab at your data. While Andrea is right and there is some slight tilt/misfocus in your image, it's definitely salvageable (though I agree to sort that out in the future).
All in all the data is decent, there just isn't enough of it to really bring out the details in this area. I don't know the gear/exposure infos, but I assume its not more than a couple of hours. Going deep is always worth it!
Ultimately the image came out quite soft, because of the heavy noise reduction applied. This is highly subjective, but I for my part prefer more depth at the sacrifice of some perceived detail.
As for the processing, this is what I did:
- Linear (PixInsight)
- Rotate
- Crop
- BlurXT
- DBE
- SCNR
- StarXT
- Noise XT
- Histogram Transformation -> Export Luminance, RGB, Stars image
- NonLinear (Photoshop)
- Recombine Stars + RGB
- Adjust Colors (ChannelMixer/ColorBalance)
- Boost Blues
- Noise Reduction
- Star Reduction
- Recombine LRGB
- Final Color Adjustment
- Saturation Adjustment
I hope this helps you
CS Julian
Thanks SkyHoinar Those pictures are super great, Loving the rich details in the hydrogen you brought out. What is the Selective Color Correction?
Regarding your questions
Integration time is 193 x 20 seconds which is an 1 hour 4 minutes.
Duo band filter is SV220
I don't think I used dither or drizzle.
Selective Color Correction is a tool for color adjustment and it is part of a toolbox for PixInsight that you can find here: https://www.ideviceapps.de/pixinsight-toolbox.html
Once installed (instructions on the website) you will find it under Script => Toolbox
Thank you for sharing the capture details!
Very short exposures, only 20 sec. and though the information is there. I am sure with more integration time you will get more details (and more blue :-).
I was actually preparing to shoot this target myself too as my next project.
I took a couple of subs (7x300 sec.; 35 minutes in total) few nights ago at the end of a session on the Cygnus Loop, just to prepare the framing.
After a quick processing, this is what I've got. It looks promissing.
Clear Skies!
Was the selective color tool what you used to bring out more of the red hydrogen? Compared to my processing that's the biggest difference I see. How did you use narrowband normalization to bring out the blue?
I found two Wolf Rayet stars in my lastest wide field recording around NGC6888, crescent Nebula. Details are here: https://app.astrobin.com/i/z16y6z
There is no catalog of WR stars and many are too small I think, but NGC6888 and WR134 are easily recognizable in this image.
For each tile in my 3×3 mosaic I do the weighted batch preprocessing, I create the mosaic with GradientMergeMosaic, and in the end you do an astrometric solution of the entire mosaic which is more than 1 Gb. But PixInsight did not crash, my compliments for its stability.
What works best is a HOO combination in PixelMatch, you do the SpectralPhotometricColorCalibration, the SpectralPhotometricFluxCalibration both for narrow band images, and next a MultiScaleGradientCorrection withe the XMARS data, there is now a DR2 version. Sii does not really help, it did not work with MSGC.
Finally you stretch the image with MultiScaleAdaptiveStretch, finally you run BlurXterminator.
This is pretty much it, the challenge is to work with xifs files that are larger than 1 Gb.
When you zoom in to WR134 in https://app.astrobin.com/i/z16y6z you clearly see the oxygen arc, and some oxygen filaments. With NGC6888 it is a lot easier.
