Request for Honest and Constructive Feedback
9 replies536 views
Astro_Rick avatar
This is my first AstroBin post. I’ve been imaging for about a year and I’m looking to improve my results and learn. Moving to mono is an obvious next step for me, but for now I want to sharpen my one-shot color processing skills. I’d appreciate any constructive, honest feedback — no need to hold back. Thank you.
SH2-132 Image: https://cdn.astrobin.com/thumbs/PbdITAN8LAk2_2560x0_6EoHJVSn.jpg?v=1783263402
For example:
  • Is this background too dark? (the blacks/whites were not clipped)
  • Is the image over sharpened?
  • Is the image too denoised?
  • Is the color off in any way? (Spectrophotometric Color Calibration was used)
  • Do the stars look okay?
  • Is anything over/under stretched?
  • ect, ect…
Ian McIntyre avatar
Overall I find this to be an outstanding image. The only thing I would try differently is exactly what you’ve identified in your first bullet. And not just the background. I suspect there is much of the peripheral dust that can shine.
As far as use of tools (sharpen/denoise), to my eye you are pretty much in the sweet spot.
For color, I am not a fan of putting too much emphasis on precision of tones beyond what works best to bring out structural detail. So this looks fine to me.
I am a very poor star producer, so my judgement should be taken with a grain of salt. That said, the sizes are fine, though the cores may be a bit bold. I would bring their exposure up a tiny bit as well.
My overall impression looking at the image full frame is that it’s a bit dark. I think it would benefit from a general lift on brightness, not contrast, brightness. Zoom is limited so I can’t get right in there and properly pixel peep but the stars look reasonable and I don’t think you have gone too far with NR or sharpening.
Helpful Concise Engaging
Astro_Rick avatar
I’ve updated the settings in the image to allow for 8x zooming.
Well written
Tim Ray avatar
Hi Rick,
Great image. I agree with Tony about the lifting the brightness. NR is good. Agree with Ian about the star cores. Overall a fantastic shot. Some targets need more time than others. This might have benefited from more time on target. Your stretch to non-linear is good. Are you separating out your RGB channels and processing separately or processing the image natively combined with your OSC? Something to explore and will prep the skills when you make the leap to Mono. I would say you are ready! Go ahead and jump. The mono waters are warm and deep.
Well written Respectful Concise Engaging Supportive
Astro_Rick avatar
Hi Tim, I didn’t separate out the channels on this image. I’ve begun to do this on some of my images, but I’m still learning. Thank you for the feedback.
Die Launische Diva avatar
Astro_Rick · Jul 7, 2026, 01:03 PM
  1. Yes. Actually the entire image is underexposed (see 6).
  2. No.
  3. Yes.
  4. We can’t tell as this seems to be made with narrowband filters. Personally I find it too red overall, as most of your gallery images.
  5. Maybe towards the small side but this is a personal preference. If you increase the exposure they will improve for sure.
  6. See (1), the entire image is understretched (underexposed).
Kael Penrose avatar
SH2-132 Image: https://cdn.astrobin.com/thumbs/PbdITAN8LAk2_2560x0_6EoHJVSn.jpg?v=1783263402 fnf
For example:
  • ect, ect…
I agree that a small brightness lift would help, especially in the fainter outer nebulosity. I would keep the sharpening and noise reduction where they are though, since the image still looks natural rather than overly processed.
Well written Concise
Aloke Palsikar avatar
Agree with most of the suggestions given already. The image can be a tad brighter with a better contrast if possible
Also the Stars though properly pinpointed are a bit under exposed. Even though you may want the stars not very bright to me a bit more stretching mat help in case you have separated them from the main image
Overall a good composition nevertheless !
All the best !
Supportive
ValeryL avatar
Hello,
I’m not as experienced as others but here are my first impressions when looking at your picture :
  • there are many stars in the FOV, they are kind of solft and lack colors
  • nebulosity is well processed
  • background level is ok for me
  • i see no issue with deconvolution or denoising
Did you use stars from dualnarrowband data?
If yes, I would suggest taking separated subs with UV/IR cut filter, short exposure time.
It would give sharper stars, less stars and they will be easy to process, you could boost saturation to get more colors.
I know it’s a pain with OSC and no filter wheel… When I was shooting OSC, I never took separated frames for stars :)
