What’s one astrophotography tip that helped you improve?
26 replies872 views
Davide Fontana avatar
Hi everyone!
Astrophotography is full of small discoveries that can make a big difference: a better way to plan a session, a processing habit that avoids problems later, a framing choice that improvedsa target, a gear lesson learned through experience, or a research that helped you understand what was possible with your setup.
The goal of this thread is to collect helpful tips and spark a discussion that other members can learn from — beginners and experienced imagers alike. We’ll feature this post in the newsletter and link back to the thread so readers can explore the full conversation and add their own thoughts here on AstroBin.
This post will be featured in our upcoming bimonthly newsletter, so more community members (no matter their experience level) can benefit from these shared tips, lessons, and learning moments.
We’re especially interested in tips that can be connected to real examples. If possible, feel free to include:
  • An AstroBin image that illustrates your tip
  • A target, camera, telescope, filter, or setup you searched for
  • A comparison that helped you understand something
  • An example of how looking at other AstroBin images changed your approach
Some prompts to get started:
  • What’s one tip you wish you had learned earlier?
  • What did you learn by studying images from other astrophotographers?
  • Have you ever searched AstroBin for a target, gear setup, or technique before planning your own image?
  • Did comparing similar images help you make a better decision about framing, exposure, integration time, filters, or processing?
  • What advice would you give to someone trying to improve with equipment similar to yours?
Your tip can be about anything related to astrophotography, for example:
  • Planning a session
  • Choosing or framing a target
  • Exposure time and integration
  • Calibration frames
  • Processing workflow
  • Comparing gear or setups
  • Learning from other AstroBin images
  • Staying motivated through difficult nights
A helpful format could be:
Tip: Keep it short and specific.
Why it matters: Explain the benefit in one or two sentences.
Example: Share an image, search, comparison, or situation where this helped.
Level: Beginner / Intermediate / Advanced / Useful for everyone.
For example:
Tip: Before buying new equipment, look at images made with gear similar to the one you want to purchase.
Why it matters: It helps you understand what is realistically possible with your setup and what improvements may come from technique rather than new hardware.
Example: Search AstroBin for images made with your camera, telescope, or lens, then compare targets, exposure times, filters, and processing styles.
Level: Useful for everyone.
Thanks in advance for sharing your knowledge and experience. We’re looking forward to reading your tips and the discussion around them.
Clear skies,
Davide
Well written Helpful Respectful Engaging Supportive
Working your way up in this hobby you’ll find many realizations as you progress. Overall, the best tip I can give is to find out what the experienced imagers do. It won’t give you the skills as that takes time but it will put you on the right track and keep you from falling down the many rabbit holes you’ll find along the way.
Well written Respectful Engaging Supportive
SonnyE avatar
Decide on what your interest lies in, then pursue that end.
Mine is DSO (Deep Space Objects) Nebula specifically. So my equipment and telescope are aimed toward that goal. I’ve owned 2 telescopes, and wore out 4 main cameras, and 2 guide cameras, and 2 mounts in 16+ years now.
So often I’ve seen posts where a beginner wants to engage DSO, Planetary, and star clusters. There is no one size fits all. Planetary has its specialties, DSO has its, and Star clusters are all over the place.
My experience was to decide on my interest, then pursue how to do that interest. Some folks want to buy the wrong equipment for what they seem to want to pursue in the hobby. And some seem to become collectors of telescopes with none being right for their interest. Which is fine, just say you want to be a collector.
When one finds an interest, study how to achieve that interest. Do your mind changing before you have a room full of equipment you rarely use.
One good tip I received was that small telescopes can do a lot for Nebulae. I used my 80mm Triplet for over 9 years before I decided to upgrade.
Gilmour Dickson avatar
SonnyE · Jul 9, 2026, 05:51 PM
This is great advice. There is a whole movement of people that seem to think you are not doing it properly if you are not shooting at 1500mm FL…. If that is what you want to go for then great, but personally I get huge enjoyment from wide and ultra wide. As Sonny said - try and figure out what you like early.
Planning framing, spending time on here, spending time with Stellarium and different sky surveys. Do your ground work first. Same as in any endeavor.
Don’t compare yourself to others. Carve your own path. Listen to those that have carved that path before you, but don’t take it as gospel - we all learn best from our own failures and successes.
It is a very “gear centric” hobby. Sometimes step back, get out to a dark site with just a DSLR and some binoculars and look up. There is more “gear” in this hobby that just about anything else other than boats and cars and planes… If (like me) your gear financial choices are Corolla and not Ferrari then fine. Just work and get good, and get satisfaction from doing as well as you can with a budget. You and others will respect that as you push your gear… even if it is a seestar. The gear really doesn’t matter - your enjoyment and use of that gear does.
If it starts to become too hard in any way, shape or form - or becomes consuming - then just remember that we all started trying to capture the utter beauty of the night sky. Whether we saw it with our eyes from a dark sky, or were hit with the realization that it can be “seen” with filters from suburbia.
Never loose the curiosity that led you to this point of wanting to capture what so few can and do. If you do loose it and move on then fine, we all change and move on as people - hobbies can be fleeting. It is their very nature!
Lastly - it is photography. There is no rule book and no right or wrong way to do any of it.
Nicolas Molina avatar
Long integration times and learn post-processing.
Peák Gergely avatar
Stars are part of the image. Let them shine. dont supress them
Bill McLaughlin avatar
Peák Gergely · Jul 10, 2026, 01:44 PM
Part, but often not the actual subject. Too many stars can drown the subject.
Peák Gergely avatar
Bill McLaughlin · Jul 10, 2026 at 04:30 PM
There is a balance. See too many pictures where the stars drowned. Not natural
Astro Hopper avatar
My best advice would be to go to as darkest place as you can!!!!!!
Craig Towell avatar
My best advice for newbies is to stop trying to image multiple targets in one night, and start spending multiple nights on one target.
Well written
Dan Watt avatar
Get into visual if you aren’t already.
There will be a point in your imaging journey where you are experienced enough to have the rig largely automated. And if you’re driving to dark sites to do your imaging, once you are set up it can get pretty boring. An 8” dob is CHEAP compared to the various stuff needed for imaging. I’ve probably spent more on random camera adapters then the cost of a full 8” dob.
It also gives you a different perspective on what a lot of targets can look which can be inspirational towards processing approach. Of course it’s going to be much, much fainter (if visible at all) but there is still value in it. Take m42 for instance… absolutely spectacular visually but I’ve seen very few images that truly capture it, instead trying to compress the whole dynamic range into as much detail as possible.
I remember a night with my 20” dob exploring M24. It was never on my radar as an imaging target but I got absolutely lost in it, there is so much going on! And it was that much more satisfying during processing, remembering that little cluster there or that dark cloud or what have you, since I’ve seen them with my own eyes.
I know it’s not for everybody but personally, I don’t think I’d still be doing astrophotography anymore if it wasn’t for visual astronomy reinvigorating me. It’s fun again.
Alex Nicholas avatar
12 amazing datasets a year is better than 4 average datasets a night…
I came into this hobby like a bull at a gate and I wanted to image EVERYTHING. I woulf give targets 2 or 4 hours max, then off to the next…
my images started to greatly improve when I realised these targets we shoot… They're not going anywhere in my lifetime… if I dont get to M42 this year or even for the next few years… who cares… it will still be there in a decade… I try to pick 2 targets per season to image, and plan to give them between 10h and 25h each.. weather loves to throw a spanner in the works but I either make do with what I have, or bank the data for next year…
I will almost always throw some contingency targets in my plan, a 2.5hr star cluster, or a 4.5h bright nebula… But, the moral of my story…
Take your time… Give the target the integration time it deserves… i find 10~15hrs produces absolutely good enough data sets, i dont see then need to go to 40~80hrs on a target, but 10~15 is sweet, 20hrs is almost always more than adequate… if you focus your efforts on fewer targets with longer integration times, you will have more high quality images… not to mention, in 5 years time when you go to do a reprocess, you will thank yourself that you have a decent data set.
Vroomfondel avatar
Take the time to look at and really appreciate each and every integration you make.
The accessibility and ease of use of modern technology run the risk of making one a bit blasé at time.
Find the hidden detail. Look for the furthest object (Quasars anybody?), or the nearest object. Zoom out/zoom in. Play with colours. And so on…
Well written Respectful Concise Engaging Supportive
The single best thing that transformed my imaging was a $100 home made pier setup and a cover. Next was automation in terms of a focuser, rotator, flat panel, wifi link etc etc. But leave that aside - just the pier and the cover is the real game changer. To go down, switch on, focus and then run a imaging session EASILY transformed everything. I cannot stress this enough - if there is a way to have your gear out and set up it will utterly change your imaging.
Gilmour Dickson · Jul 11, 2026, 06:04 PM
I would 2nd that. That’s what I do and it’s wonderful. In my mind it’s well worth trading a Bortle class or two to get it.
ItsMeAstro avatar
Switching from EQMOD to GSS and switching PHD2 to Innovations Foresight Skyguide for much better guiding. See : https://www.innovationsforesight.com/skyguide-and-skyguard/
Guy Marshall avatar
Tip: Do not target-hop, focus on one target for a long time.
Why it matters: The final image of this single target will have lots of detail and signal. Otherwise the multiple shorter total exposure time images of different targets will look noisy and faint in comparison.
Example: Focus on M63 for multiple days/weeks in a row, instead of shooting for a few subs on one galaxy then moving to another galaxy and repeating. Then if you want once you have enough data on M63 you can move to another target such as M13!
Guy Marshall avatar
Tip: The best telescope is the one you will use the most.
Why it matters: Buying a super large telescope with a heavy-duty mount and tripod is good, but if it means you don’t want to use it because it hurts your back or you don’t have the strength or motivation to move it, it will be a waste. In this case, a smaller telescope that in theory is “worse” but gets more use because it is more practical is better.
Example: The EQ8-R mount alone is 25.8kg, and when paired with a Quattro 300p at 21.8kg it means the total (with counter weights) will be over 50Kg! This combo will give fantastic results, but if it is too heavy to move and use (which it is for a lot of people), then it isn’t worth it. A smaller MK127 and AM3 mount, or even a small refractor, although not as good at gathering light, will be better because they will be used more often.
Aloke Palsikar avatar
My best tip which I have learnt is to research the object before hand and get to know the composition of the elements, gases etc and zero down on the filters before imaging. For e.g. Imaging SH2-308 or the Dolphin Nebula requires more time of OIII and SII may not be required at all
Prior research helps in getting the best out of the imaging session.
Jason Smith avatar
Don't forget to have fun. That's why we all started. If you're not having fun, you've lost your way somewhere along the journey.
Jonathan Paul avatar
Just reading this feels like homework.
Rafał Szwejkowski avatar
Less is more when it comes to processing. Most of the “fancy” scripts out there don’t make an image better.
John Stone avatar
ItsMeAstro · Jul 11, 2026, 08:14 PM
I really want to learn more about this.
Did you buy the ONAG that allows for full-frame IR based guiding?
Or did you just switch from PhD2 to Skyguide?
In either case I’d really appreciate a full explanation of the details.
Thanks.
ItsMeAstro avatar
Hi John,
There’s a lot to tell about SkyGuard or the more extended SkyGuide which also offers realtime (!) autofocus with appropriate special optical adapter who’s purpose is to to introduce a specific astigmatism into the guide beam, neccesary for realtime guiding.
For guiding only a regular OAG with NIR-sensitive guide camera, like Lodestar PRO, will work, but it’s strongly recommended to add a filter to the OAG, so all visible light will be blocked below 700 nm.
Recommended filter : 31 mm , unmounted, Chroma NIR filter which fits all standard 1.25” OAG adapters, see https://www.chroma.com/products/parts/27054-i-bessell/
The 27054 I-Bessell bandpass filter transmits a single spectral band while blocking light on either side.
Guiding in NIR strongly surpresses air turbulance (twinkling stars), so stars and other information reaching the guide cam will be more stable, which already improves guiding, even with PHD2 !
However Skyguide uses full-frame information and doesn’t depend on stars only, like PHD2 and in my case double the guiding accuracy.
The more advanced option is using SkyGuide, as I do, which combines autoguiding and autofocus but in that case you need a special adapter, the Lacerta for Lodestar and is combined with the NIR filter in my case to get the optimum and most accurate results. I would prefer the ONAG but was impossible in my setup due limited backfocus, so I’m using my OAG and Lodestar PRO.
Here is exactly how the software suites handle an OAG + Lodestar PRO setup without an ONAG or Lacerta adapter:
1. SkyGuide (From the SkySurveyor Suite)
  • Compatibility: Fully Compatible. [1, 2]
  • How it works: SkyGuide is designed for guiding only. Instead of tracking a single star centroid, it uses digital image correlation to track the entire field of view (full-frame guiding). [1, 2, 3]
  • OAG Support: The Innovations Foresight SkySurveyor documentation explicitly states that full-frame guiding works natively with standard guide scopes, self-guided filter wheels, and traditional Off-Axis Guiders (OAG). [1, 2]
  • Requirement: Your Lodestar PRO just needs to connect to the software via its standard ASCOM driver. [1]
2. SkyGuard (From the SkySurveyor Suite)
  • Compatibility: Guiding works, Autofocus DOES NOT. [1, 3]
  • How it works: SkyGuard combines the full-frame guiding of SkyGuide with real-time autofocusing capabilities. [1]
  • The Catch: The continuous, real-time autofocus feature requires a physical optical element to introduce specific astigmatism into the guide beam. Without an ONAG (which inherently has a dichroic cold mirror) or a Lacerta for Lodestar adapter (a physical lens attachment), the software cannot calculate focus changes. [1, 2, 3]
  • Result: If you buy SkyGuard, it will default to working as a standard full-frame guider, but the real-time focus feature will remain completely disabled
It’s a real improvement for guiding and focising and it even works without stars being seen and light clouds (!), but it’s quite different from PHD (Push Here Dummy) , as the setup is rather complicated and reading the full manual (very strong recommended !) takes some time, but eventually it’s really worth the investment !
However, nowadays, AI bots (ChatGTP or Claude) could be be very useful and create a step-by-step instruction list for full and very detailed setup and optimization, but reading the manual will help to understand tuning the parameters !
Succes !
ItsMeAstro · Jul 13, 2026, 11:05 AM
I’ve been trying to convince people of this for awhile now…..
