donld · Aug 19, 2026 at 04:44 PM
Most newer sensors don’t have unity gain anymore. Newer sony sensors mostly have HCG mode. On my particular camera just about everyone leaves it at gain 100.
That’s not correct. I run a Sony IMX455 sensor, which is not an old sensor and depending on the camera that it’s installed in, there are a variety of read modes available, which all include unity gain. I see from your profile that you are running the smaller version of same sensor in a ZWO ASI6200MM-Pro. The sensor itself in that camera is fully capable of unity gain. It is your camera manufacturer that limits the gain to 0.8 -e-/ADU; not the sensor. QHY Cameras on the other hand, provide 5 different read modes that gives access to a wide variety of trade offs between gain, well depth, and read noise. Still, at a gain of 0.8 e-/ADU, which is slightly more than unity gain, your ASI6200MM provides a well depth of 51k photo-electrons. That’s less than what I get out of my Moraivan camera but not by enough to matter much. At gain 100 in your camera, you are operating at the lowest possible read noise and that’s great, but you are also losing over half the well depth at about 19k e-. Operating that way works just fine, but you’ll need to use shorter exposures by at least one half to avoid overflowing the wells and saturating the stars. With such low read noise, you can go fairly short but you’ll end up with a LOT of data to process and you need to be careful about some effects due to read noise that not many folks pay attention to.
Remember that the reported RN for any sensor is only an average and it doesn’t accurately capture what happens with random telegraph noise (RTN) that occurs in CMOS sensors. RTN causes “salt and pepper noise”, which becomes a more significant problem as it becomes a significant fraction of the photon noise. So, be sure to dither often. This can also be mitigated by using longer exposures and by 2×2 median filtering your subs. It’s a “Goldilocks” story. Your exposures can’t be too long or you saturate too many stars and they shouldn’t be too short or you’ll have trouble with RTN.
