Calibration frame strategy for multi-session narrowband imaging projects
17 replies186 views
Nadeem Syed avatar
Question for those running multi-night mono narrowband projects, how are you handling calibration frames when a project stretches out over weeks or even a month (realistic for Irish weather)?
Specifically:
• Do you reshoot flats for every filter each time you image, since focus shifts with each filter change, even within the same night?
• Is one flat set per filter valid for the whole project as long as the imaging train isn’t touched?
Shooting with Askar 103mm + Touptek 533M with Ha/OIII/SII/RGB, imaging train stays fully assembled but comes off the mount and indoors between sessions. Curious what’s actually necessary vs. overkill in that setup.
The slight focus shifts involved will not affect your flat frames.
Some people will say that if the system is sealed and you never change rotation then one set of flats will last forever. I suppose that is true however, it’s a risk. You never know if there is a bit of dust or a hair that will suddenly decide to visit your sensor window or filter. Taking flats is so quick and automated if you use NINA, I just can’t really see a good reason not to take them for every session, as insurance if nothing else.
Dave Ek avatar
I shoot sky flats around sunrise after every night I shoot. PixInsight’s Weighted Batch Preprocessing script makes it pretty easy to calibrate each night’s subs with corresponding flats. I use the NINA FlatWizard, which makes it quite simple and quick. It does, however, mean that I have to be up before sunrise. :-) I’m not concerned with focus shift so much as I am with dust and other stuff that enters the system and moves around.
Well written Helpful Respectful Concise Engaging
Since you’re using NINA why not automate your sky flats by including that in your sequence? If you throw in a flat session at the beginning and at the end of the night, you’ll have protection if clouds show up in the morning. In any case, you can sleep in!
Tom Boyd avatar
I set up and take down every night. As such, I shoot flats at the end of every session…
Quinn Groessl avatar
I use my dark library for darks and bias. I’ll shoot flats most mornings, but for sure if I have torn down the set up between sessions. I shoot sky flats and even if I have to take them for all 7 filters it only takes 5-10 minutes tops.
Nadeem Syed avatar
Thanks all, this has been really helpful. Sounds like flats should be per-session and per-filter especially since my rig comes apart between sessions.
One question on the “flats at start and end of sequence” tip, wouldn’t start-of-sequence flats miss any dust that lands on the front element during the actual imaging run? Seems like end-of-session flats are what actually protect against that, since they reflect the train’s state after the night’s imaging rather than before.
There have been many instances where I have to bring the kit inside middle of the night due to cloud cover which usually are followed by rain here, so sky flats are usually not possible.
I got a tracing pad and use that to take flats inside using NINA Flat Wizard.
During my last image, which I started in April and short over many short sessions got it done last week. But used just one set of flats and this prompted by question.
What do you guys think about telescope mounted flat panels? Though they seem to be one the pricey end.
nadz11.ns · Aug 18, 2026, 08:45 PM
That was really more about clouds, not changes in the state of the dust.
In your case, new dust is probably more likely right from the beginning but if you double up the flat session, you’re covered both ways.
Also, it should be noted that dust on the front element has no effect and doesn’t show as a dust mote. It’s dust much closer to the focal plane that you need to worry about.
Some swear by them, some swear at them. They are pricey and the sky is free.
The other thing is that if your OTA doesn’t have any light leaks, and if you have a camera that behaves well with short exposures, you can actually take them in the middle of the day if you have to.
Well written Concise Engaging
Dave Ek avatar
Tony Gondola · Aug 18, 2026 at 06:07 PM
I could do that, but when I say I shoot sky flats, what I really mean is that I shoot white t-shirt flats. So I need to be up to place the white t-shirt ( actually use white t-shirt material in an embroidery hoop).
What’s the t-shirt for?
Nadeem Syed avatar
Tony Gondola · Aug 18, 2026 at 08:54 PM
ah, i didn’t know that front element dust doesn’t affect much.
I will incorporate flats in the beginning of the session into the sequence and try to double up where possible.
Thanks
Nadeem Syed avatar
Tony Gondola · Aug 18, 2026 at 08:59 PM
Ya, those branded once cost as much as a new OTA sometimes 😅
My Askar 103 seems robust as I haven’t seen any light leaks in the subs.
Bill McLaughlin avatar
Tony Gondola · Aug 18, 2026, 08:59 PM
I have used either scope mounted flip style panels for my refractors or wall panels for the larger scopes for decades. I have never had any issues with any of them except once. That was with a wall panel which sadly attracted a large moth one night! Fixed that by running a bug zapper for a few minutes before each flat session. ⚡️
A well sealed flip panel for refractors can also make darks a breeze for the 90% of cameras that do not have shutters. I prefer the Deep Sky Dad units due to their tight light/dust seal and their ability to get very bright which means you do not need a lot of longer flat exposures for narrowband. Very well thought out units and better than the old Optecs and the less well sealed Wanderers.
I abandoned sky flats decades ago and have never looked back. They are just too fussy in terms of gathering them and were not any better (and sometimes worse).
With a well sealed system (and any other kind is not acceptable) that has not been broken down (which is a PITA anyway) I do not take new sets of flats very often, maybe every few months.
Gotta do some tonite though. We just came out of a wildfire evac status 🚒🔥so I reassembled my AP 155 system today after boxing it to take with me. 🚚
Well written Helpful Respectful Engaging
donld avatar
Deep Sky Dad works great in my experience. On a pier, flats don’t necessarily have to be taken each night. But people on piers are usually automated so flats take no effort. I’m curious what standard practice is for people on piers, either home observatory or remote. I have seen a few people with home observatories mention SD cards, which is surprising .
Nadeem Syed avatar
Bill McLaughlin · Aug 18, 2026 at 10:25 PM
donld · Aug 19, 2026 at 04:32 PM
Thanks both.
Good to hear the Deep Sky Dad panels are working well for you. Given my situation, I think a flat panel is the right call for me. Sky flats just aren't reliable given how little control I have over timing. Going to look into the Deep Sky Dad units.
Well written Respectful
Tony Gondola · Aug 18, 2026, 09:28 PM
It diffuses and cuts some of the light, and it just makes all the light coming in uniform. I used to use a t-shirt, but I designed and 3D printed a thing use a translucent acrylic sheet to do the same thing. If I ever make another one I want one that blocks even a touch more light so I can take a bit longer flats.
Martin Dowd avatar
I image from 2 different locations
Bortle 8 City suburban backyard permanent set up ( 8” f5 Carbon Newt , self built )
Bortle 3 Rural NexDome Obs ( 10” f5 Carbon Newt self built )
Camera ZWO2600MM
Filters Antlia
I take one set of calibration frames per project (object ) irrespective of how many nights I gather data
Flats for each filter taken with A3 and A2 Huion led light dimmable tracing pad with additional 3mm layer of opal acrylic
Darks to calibrate Lights from library ( library renewed every 12 to 14 months )
Flat Darks to calibrate Flats
No issues at all over the past 3 years or so
Clear Skies
Martin
Helpful Respectful
