Uploading and viewing two images simultaneously
Kevin Dixon avatar
Is it possible to upload two images so that they can be viewed simultaneously? If yes, can you please describe the steps to do so. Thanks!
Well written Respectful
Put them side by side (as a single image, obviously).
Kevin Dixon avatar
Thank you Andrea. When you say put them side by side, is that done on Astrobin or must that be done with the image processing software?
Outside of AB. Easily enough done in PI, for example.
Bob Meincke avatar
Kevin, from what I’ve seen, Andrea is correct. You’ll need to create your own mosaic outside of AB. That said the mouse over function works quite well if the images are identical in size. This can produce a blink type scenario where on/off shows one image or the other. On mobile you click the target icon for the mouse over effect.
Well written Helpful Respectful Concise
Kevin Dixon avatar
Thanks very much Bob.
Clear skies,
Kevin
